Well, it never fully died to be honest. I could still drive it... From what my transmission shop told me the belt probably got stretched a bit due to the torque so that's why I was experiencing some slippage when driving it. But the first sign of it appeared about 6 months after the turbo install.suprspinner wrote:how long did your CVT last ranga? what was the cause of its death?
There's one guy in Cali that had his turbo put on a little before mine and he's holding up fine. But from what I know he's the only one that has held up.suprspinner wrote:so the CVT really cant handle anything... the swap is a must then?
Where can you find these things? Ive been looking for a thicker / new belt, and a higher output torque convertor, but can't see it anywhere.Ranga14 wrote:New belt, upgrade the torque convertor and get a transmission cooler. Those are really the main options but good luck finding a place that is knowledgeable on the CVT, it won't be easy.
Ranga14 wrote:Updated: total hours for clutch install should be 12.3 hours, most shops will quote that however a Nissan tech friend tells me it's actually 10 hours. But if you have a turbo kit like me then 12.3 sounds right.
