For the "pros"
WONit
Car: 89' 240sx Redtop
OK after having my redtop sr totally rewired i still have NO spark. the ecu ,ignitor
chip,+ coil packs have been tested on 3 other cars! all the grounds have been
ground down to a clean surface . ALL fuses checked.. but still NO spark. anyone
have an idea of what it could be? i have had this car with the swap for almost a
year ,and am kinda getting fed up with it... any ideas would be helpful!
TY, WONit
Onizuka
Car: 91 Nissan S13 coupe SR20DET
89 Nissan S14 hatch SR20DE
This may sound rediculous, but if you have a really generous freind with a SR swap, test your whole harness on their car. Crank angle sensor working? If thats broken it will stop the ignition. If there was a short somewhere you would be blowing fuses, so I'm really at a loss as to what else it could be. Battery charged? lol..
WONit
yea, it turns over fine , no fuses were blown, CAS has been tested so i know its fine... we are all at a loss .... im goin to try and find someone to swap out harnesses with!
AJ1356
when you trun the key does it do anything ?? or it is just all quite ?? also was your car an automatic b4 or not. if it was an auto then i have a selution for you. try it and it would work like a charm. let me know and i can take a pic of what you ned to do.
WONit
Nah , it wasnt an aoutomatic befor,and it turns over fine,geting plenty og fuel...
just NO spark whatsoever. befor it would give me spark on random cylinders,but
none now!
Hijacker
Car: '92 240sx Convertible
'94 F-150
are positive you have no spark? like you've pulled a coil pack and watched to see if it can arc a spark plug? (ghetto way I've done it in the past is to put a plug in the coil pack, touch the electrode to the valve cover and stand clear while I crank the car)
climaxsr20
Car: 1998 Silvia RedTop
what kind of spark plugs are you using?
WONit
yea, i tested the plugs that way. i dont know what the plugs im using are
called.. heyre the one HT sent me with my swap package... and i have tested for
spark with numerous misc. plugs also... i can hold the spark plug so i know
there is nothing there!
cIvIcKILLA240style
Holy hell I have not been here in a while. The full harness has been removed and completely opened up and all wires in it have been checked. Like he said all sorts of stuff have been swapped from running SRs. I am out of ideas as to what is stopping the motor from providing spark. Do you still have the old lower SR harness?
Nismo_Freak
Car: 89 Nissan 240SX
Sounds to me like you have a wiring issue.
Trace point to point for voltage, mark where it stops.
cIvIcKILLA240style
Nismo_Freak wrote:Sounds to me like you have a wiring issue.
been done
WONit
HT never gave me a lower SR arness,when i called about it jeff told me that i
didnt need it and the lower KA harness would work fine!
Nismo_Freak
cIvIcKILLA240style wrote:been done
Do it again, obviously you overlooked something somewhere in the process of testing everything else you wouldn't have made this post...
biglipzit
Car: sr20det S13 RHD 200SX
maybe ur ecu isnt good? i havent heard anyone mention the ecu... but yeh did u test the CAS?
WONit
yeah, i put the ECU on my cousins car and it worked fine.... as far as i know the
CAS has been tested also
climaxsr20
maybe its a sign that you cant have an sr20det. haha. kidding. the only thing i can say is you gotta go through the whole process again to double and/ or triple check everything you did. maybe you might have missed something. my brother and i had to do this a couple of times to get the rb25det started.
yellow_jacket
Car: 95 240sx
It really sounds like you have a missing ground somewhere. And what did you mean by "as far as I know the CAS has been tested?"
Did you check for power at the coils as opposed to just checking for spark?
Did you check the coil pack harness?
Did you check continuity from the coil pigtails all the way back to the ecu?
Did you check the ground wire on the ignitor?(iirc that ignitor has a ground wire on it. 5 in 4 out)
What about the ecu? Are you sure it is turning on? Is it staying on when the key is in the start position? Have you checked to make sure the ecu is not losing positive power or negative ground?
Did you check for injector pulse using a noid light or how do you know it is getting fuel?
Hopefully you haven't checked one of these things and there you will find your answer.
WONit
what i mean by that was, my car is at a shop ,and i was told that everything
was tested, but just like everything if you cant see it with your own eyes you
cant say for sure that it was done
now before the harness was pulled , i know that continuity was checked from the ECU to the coil packs...
as for the ecu ,when i bought it,there was no light so i cant tell by eye if it is turning on or not!
and before the harness was pulled ,i lifted the injectors up while having the key turned . and i pulled the fuel line the other day when we tried to start it(this is with the newly redone harness) and fuel was getting to the injectors!
Hijacker
'94 F-150
yellow_jacket wrote:Did you check the ground wire on the ignitor?(iirc that ignitor has a ground wire on it. 5 in 4 out)
IIRC, the SR harness grounds the ignitor at the ECU. Could be a bad ground on the ECU's part
WONit
will check and get back to you all!
zippe
Car: Nissan 240sx
Have you checked the Cam Angle Sensor??? And if the wiring is reversed to the cam angle sensor it will not work either (causing no spark)… what year car is it and red or black top
S14Life
Car: b5 s4 stage 3, 2001 pathfinder, 91 s10
you know the CAS and the ignitor in plugs are pretty much the same.. make sure you have the colored wires going to the ignitor and the black/white/grey whatever going to the CAS. also, did you get like a redtop hanress with a blacktop ecu? or vice versa?
WONit
Im not 100% positive, but i think it is a E5 ECU... not sure if it is redtop or blk top ecu.. and im gonna give the shop a call tomorow ,and ask them to double check the wiring,and test the CAS again!
S14Life
e5 is blacktop type x ecu. i'm pretty sure the pins on the e5 differ from regular blacktops..
Hijacker
'94 F-150
I have an E5 ECU that works fine on my old redtop setup. E5s were from blacktops, but not necessarily type xes
WONit
yeah, and i did put the E5 ecu in my cousins car which has a a redtop in it,and it worked fine!
cIvIcKILLA240style
yellow_jacket wrote:It really sounds like you have a missing ground somewhere. And what did you mean by "as far as I know the CAS has been tested?"
all been done
cIvIcKILLA240style
S14Life wrote:e5 is blacktop type x ecu. i'm pretty sure the pins on the e5 differ from regular blacktops..
wrong
S14Life
MY BAD
i had the e5 and actually the kind folk here on nico told me it was a Type X ecu and that it was different.
S14Life
niver mind. I got the E and J mixed up. J4 was the type x ecu
