For the guys running high boost!
rb25drag
Car: 1990 Nissan 240SX 5.3 Chevy + 60mm turbo + blow threw carb.
What Size waste gates are you guys running to handle 25-30PSI? Most of what im finding is the 38-44MM gates.
Im getting my car ready for the Propane setup Finally. I plan on running upwards of 28-30PSI Maybe, Unless Its going to give me Alot of lag at the track. If so Then I will raise the compression of the motor to somewere around 13:1, and lower the boost to around 15-20PSI.
But I need to know What waste gate I am going to need for this application, I was thinking 50mm?
Im also going to buy a CHEAP OBX manifold and Modify it to my liking and port it to flow some good numbers at the machine shop. ( I figured the hours involved in making one from scratch and the materials required and Im Money ahead in buying a cheap one and Modifying it).
I also like the V-band clamp wastegates, Everyone I know says the seal good. Anyone on here have one?
fast_s14
Car: 94 300zx
My rb25 isn't running yet but i am going with the tial 44mm with 1 bar spring.
my set up consists of:Gt3076r turbo6boost manigreddy type r bovtial 44mm
rb25drag
From what I have read the 44mm is only good for about 1-1.4 bar, which I could possibly run over 1.5 bar IF my setup goes as planned. I think the 50Mm will cover it, But I would like someone to confirm my theory.
craz4240
Car: 1995 240sx w/rb20det
Synapse 50mm v-band gate
BHFR-GTR
Car: 1993 s13
im running twin synapse 50mm on the fullrace mani-rb26
Cjmartz2k
Car: Hunting for a '89 GTR now
The higher the boost, the smaller the WG can be. It seems backwards, but it's the truth. Also, how much are those XS power mani's? I would strongly suggest the Stec ones that Fearsometea had up here a while ago. I'm running one now and think it kicks ***. They are only $400, so not super cheap, but way better quality than that ebay crap.
rb25drag
Cjmartz2k wrote:The higher the boost, the smaller the WG can be. It seems backwards, but it's the truth. Also, how much are those XS power mani's? I would strongly suggest the Stec ones that Fearsometea had up here a while ago. I'm running one now and think it kicks ***. They are only $400, so not super cheap, but way better quality than that ebay crap.
so your saying a 38mm or 44 would work?I seen those synapse gates, seemed to be a decent price, just wasn't sure about the quality. So what kind of boost are you guys pushing with them?Also the manifold you suggest, I would like some more info on. Were can i find one? I would give 400$ for a decent mani. I just don't have 1500$ for a full race. im a poor man. Also is it a top mount mani? Also for the s13 hatch guys with top mount manifolds, how close is your hood? any problems shutting it?
240z4u
Car: '95 Nissan 240SX
Yeah smaller gate for higher boost is fine, it has to bleed off less exhaust pressure to control your boost. The real trick is having an efficient setup to get the exhaust to the WG and out of the WG.
I am running 23psi as we speak perfectly fine on my tial 38.
S14-NEO
Car: 1995 nissan 240sx RB25 NEO powered
im runnning a Greddy 50mm gate on my setup....works like a charm
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Like a few have said, you don't need as big of a gate with a big turbo since you're sending a majority of the exhaust gases thru the turbine and not bypassing. Most can get away with a smaller 38mm gate that results in better response.
There's a thread on skylinesaustralia about it and Sydneykid describes his method for calculating diameter. I'll see if I can find it and link here.
Darius
BINGO! Found it...about half way down on the first page for the summary, then in greater detail towards the bottom.http://www.skylinesaustralia.c...+size
And v-bands seal well if they have a male and female side, which Tial's do. I have a v-band without the groove and hub (for lack of better terms) on my turbo (which came from ATP), and I can't get it to seal perfectly. If I put both flanges face to face, I can slide them past eachother. Sucks because I'm constantly worrying if it is throwing my wideband off while I'm trying to tune. With the hub and groove, they align and interlock for a better seal. Vibrant makes their v-bands like this.
Modified by Darius at 8:44 AM 8/22/2008
240z4u
Darius wrote:BINGO! Found it...about half way down on the first page for the summary, then in greater detail towards the bottom.http://www.skylinesaustralia.c...+size
Nice tip on the vband scenario. Thanks.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
im runnign a 60mm spl vband wastegate with a screamer pipe, running, 21-28psi, with no boost creep
rb25drag
Thanks Darius, That link summed it up. I think for my range a 38mm will be perfect size.
Ya my buddy runs the V-clamp on his Turbo Mustang its very nice, makes installing easy.
The New Precision turbo I have is a V-clamp, so im going to buy a wastegate like that also, Make it all match and be easy access.
Are you guys running the wastegate threw your exhaust or just an open DP?
I Don't plan on putting any type of exhaust on it, Im running open down pipe as for now, I might bring a straight 3 inch pipe out the side so it can throw the flames on my competition at the track
BHFR-GTR
Car: 1993 s13
my car is a s13 and with the gt40 and full race mani, the hood wont close, its hitting right on the bracing, im gonna cut back some of the bracing and i will let you know i may have to have a eclipse style dent in my hood oh well
rb25drag
Cool, let me know how that works out.
If my hood hits, Ill Cut it out, Put a HUGE spacer and raise it above the hood so it will catch fresh air
LOL, J/k
BHFR-GTR
Car: 1993 s13
hahaahaha thats what im talking about
rb25drag
Kinda like this guys, Except only 1 turbo
rb25drag
Im assuming this is the manifold you was suggesting?
http://www.stec-motorsports.co...m=014
Cjmartz2k
Yup, that's the one. I'm real happy with it.
BTW, I was running a HKS 38mm wastegate with my HX35/40 hybrid which was a T3 flange, and a small turbine wheel compared to the compressor, so I had to bypass a lot through the wastegate compared to most, and it didn't creep as low as 1.2 bar of boost (that's what the spring was).
rb25drag
Sweet thanks for the tip, I def like the looks of that manifold better than the Ebay one.
How close are the ports matched up to the gaskets? Could the manifold use a port N polish for better flow?
gawdzilla
Car: none
interesting that the s-tec manifold comes with a wastegate. all for just $520. i can 99% guaruntee that the setup won't fit in an LHD car without modification. so save your port n polish/gasket match money to move the wastegate...
rb25drag
Im sure I will modify the manifold in more than 1 way. I don't look for it to fit directly, Thats why im going to buy something cheap just as a mock up and modify it to my liking and clearances of everything. Will be easier in the end vs building one from scratch like I originally planned.
SullivanRacing06
gawdzilla wrote:interesting that the s-tec manifold comes with a wastegate. all for just $520. i can 99% guaruntee that the setup won't fit in an LHD car without modification. so save your port n polish/gasket match money to move the wastegate...
yea sorry to say but that manifold will not fit, ull be better off buying a ebay manifold, having the flange that meets the head shaved so it will not be warped, ave a local exhaust shop move the wastegate so it faces foward, and buy a real wastegate for gods sake, dont trust a 90$ fake wastegate, spend the extra money and have a name brand wastegate under your hood
rb25drag
it says right on there site it will fit any RB swapped s13 or 14. So what won't fit about it other than having the wastegate moved?
If I buy it Im buying the manifold only, Im not buying that cheap wastegate.
gawdzilla
Car: none
rb25drag wrote:it says right on there site it will fit any RB swapped s13 or 14. So what won't fit about it other than having the wastegate moved?
"RB swapped s13 or 14" doesn't mean LHD. RHD cars can do the swap too.
website says "It is unknown with LHD cars if they will clear the steering". Just looking at it, I can tell you it almost certainly won't.
SullivanRacing06
agreed, buy the ebay manifold, get the flange flantened out ny a machine shop w a belt sander, and get a local exhaust shop move the w/g flange, get a 38mm or 44mm w/g thats name brand
rb25drag
Cool Thanks for the tips guys, Ill be back with pics and stuff of the setup once complete.
rb25drag
This looks like the best quality built manifold on ebay. Anyone running one on here?
http://cgi.ebay.com/ebaymotors....m245
