For the folks with dropped suspensions
All things Altima Coupe.
Cali 2 Balti G
Car: Desert Platinum G35 Coupe
Dodge Ram Quad Cab
Toyota Sequoia
There are a few out there that have lowered their cars, many have expressed interest. But I don't recall anyone mentioning alignments.
I recently had the unpleasant task of replacing my 2 rear tires due to uneven wear on the inside edges - although I think this is partly due to the stock infiniti camer - where the rear wheels are tilted in towards the top - making the inside edge have more contact with the ground. I also think it was partly due to me not getting an alignment soon after my new wheels and potholes knocking the car out of spec.
I'm assuming that an alignment is recommended for a drop.
So the questions are:Are folks getting alignments on their new drops? Are their any issues aligning a lowered car? The tires you save may be your own!!!!
Robs_altima
Car: 2004 350Z Touring
I had mine aligned simply because you have to take the strut off and reinstall it. No matter how you mark it before ripping it out, there's always the chance that it might not be back within specs. That and combining the nature of dropping a car and the slight camber change, you might have the right mixture for some problems. I don't know what kind of tire you're running but $70 for the alignment or whatever they charge you vs. wearing a set of Pirelli Zero Nero's prematurely gives me great peace of mind for spending the money. Even if it doesn't pull, you camber could naturally wear the tire unevenly
windhaven
Car: 2008 Nissan Altima Coupe 3.5 CVT Winter Frost/Blond Full Load
Cali 2 Balti G wrote:There are a few out there that have lowered their cars, many have expressed interest. But I don't recall anyone mentioning alignments.
Cali,
There's been a bit of discussion on the topic. In general, there have been two schools of thought, one to align immediately after the drop, the other to align after about 100 or so miles to let any latent settling occur.
But, overall, alignment has been a consistent choice amongst the majority. I aligned after 130 miles.
Hope this helps,-- Wind
nismofool
Car: Nissan Altima Coupe '08 3.5SE
i've dropped my car with the eibach pro-kit, and since then put atleast 250 miles on it, and i still have yet to get it aligned, no problems here.
NissNEZ08
Car: 2008 Nissan Altima Coupe 3.5SE (Premium Pkg, Tech Pkg, VDC, CVT & Blk Leather)
I honestly think it is a personal choice. From my understanding, these cars do not need alignments at all after lowering. I will let you all know what I decide to do after I get my springs installed. I would rather be safe than sorry I suppose.
Take it easy all.
T
dldjros69
Car: 2012 Evo Gsr
A/C 2.5 Turbo 6MT (SOLD)
im installing my springs this coming tuesday 4/1.
I am totally worried about getting my car aligned.
I am diy ing it. Also i am waiting 100 miles to get it aligned.
sexyinblck
Car: 08 Coupe 2.5
I just got my springs installed today, the car is noticeably out of alignment when i take my hands off the wheel but its not "diving". After 2 weeks (100-150 miles), when the springs are well set in, I plan on aligning the car!!!
dldjros69
Car: 2012 Evo Gsr
Installing tuesday. Im going to get it aligned on friday.
i hope it doesnt drive to badd.
what do you mean not diving?
stsxcrle
I installed the springs on my own, drove it about 400 miles, then had it aligned. Noticed the brakes "chattered" a little at high speeds before the alignment, now, everything is perfectly smooth, gotta love the ride of the eibachs.
I opted for the lifetime alignment plan at firestone cuz I plan on getting 18's for summer and keeping my 16's as winter tires. This way I pay once and can get an alignment every time I swap out wheels.
adidas2go
Car: Cycle through all kinds of cars, trucks, motorcycles, and boats 🤙
Once upon a time: 1st turbo Altima Coupe
Its debatable, do it if you want, just know there is a risk of uneven tire wear if you don't. Getting your tires rotated every 5,000 miles or so will help you too.
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
windhaven wrote:
Cali,
completely off topic, but windhaven, I like your car more and more everytime I see it... if my wheels get damaged, without hesitation, I will be getting the 19" MODAS
opekone_1988
Car: 2008 Altima coupe 2.5
From what I recall, according to Stillen there is no need for an alignment because the drop is Mild and not Wild. I've Driven the car for over 500 miles and no need for alignment' drives as straight as the crack in my A** .. J/K.... but seriously I checked it top to bottom and tires are straight, no uneven wear and does not slide to the side while driving at all. I'm getting my Wheels this week and that's when I'll get an alignment and balance.
niztec
Car: 2008 AlTIMA COUPE
i dont see you getting any tire wear from just 100-500+ miles, if you leave it on long enough without alignment, then after 3000+ miles then you might see some camber wear....but then again, you could always get nitto neo gens which have harder compound on the inside of the tire
nismofool
i started getting uneven tire wear.... alignment is now over with got it done today
Cali 2 Balti G
Dodge Ram Quad Cab
Toyota Sequoia
Good so I think it was good idea to start this discussion - based on the responses - folks have different opinions as to whether the alignment is necessary or not.
Niztec - you must be inside my head - I saw an ad for the Nittos yesterday -and I notice the inside edge of the tires - I may go for these next when I replace all four Kumho's.
cuzzbubba420
Car: 08 Altima 2.5 S w/ CVT
Just had my pro-kit installed yesterday and loving the new ride quality. I'm going to wait for 150 miles before aligning but as of now it seems no diffrent from before installation. It looks
Robs_altima
If you trust the person who installs the springs (mainly the front) or personally make sure you take very good care in marking the position of the strut for reinstallation, then by all means skip the alignment. The no need for alignment augment based upon the mild or wild is that you will naturally get negative camber out of lowering the car, just not a lot out of this drop. If you bolt the strut right back in place then I guess you'd be fine. I'm just not a fan on the, let's wait and see philosophy
