CROWER also makes valve lifters (hydraulic and solid) no idea if they can make for the CA18...
remember that the CA lifters are the same as the VG30DE(TT) so any aftermarket ones for them will work, so Ferrara (or whoever) makes.
this is the email address of the guy from JUN i found this from a request i had made about a year ago.
Junichi Tanaka [
[email protected]]
Quote »1. CA18DE/DET camshaft kit stage 2 JPY 140,000consisted with cams,valve springs and titanium retainers2. CA18DE/DET slide cam pully set JPY 28,000In stockThank you[/quote]and here is another contact at JUN
Yutaka Chiba [
[email protected]]
Quote »Dear Mr.Aaron
Thank you for your enquiry.We are currently trading directly from JUN head office in Japan to the customer in the USA and CANADA. You can order and purchase our products directly from Japan.
We would like to know your head spec.Is your head solid type or lash type??
Here is the price for CA18DET CAMSHAFT KIT
[#1033M-N013]Camshaft kit stage1 is JPY98,000yen.(about USD 829 dollar) [#1033M-N014]Camshaft kit stage2 is JPY140,000yen.(about USD 1,184 dollar) [#1033M-N704]Cam gears(1set) is JPY28,000yen.(about USD 237 dollar) (spcial price for kit)
********************************************Stage1 including cam(1set) and springs.Stage2 including cam(1set), springs, and retainers.as for cam profile, you can choose.********************************************
Our profile line is ;
INT [duration] 64(256) [lift] 8.5(mm) EXH [duration] 64(256) [lift] 8.5(mm)
INT [duration] 66(264) [lift] 8.5(mm) EXH [duration] 66(264) [lift] 8.5(mm)
INT [duration] 68(272) [lift] 8.5(mm) EXH [duration] 68(272) [lift] 8.5(mm)
INT [duration] 66(264) [lift] 9.3(mm) EXH [duration] 66(264) [lift] 9.3(mm)
INT [duration] 68(272) [lift] 9.3(mm) EXH [duration] 68(272) [lift] 9.3(mm)
*****Custom-made cams cost*****Intake camshaft JPY24,000yen.Exhaust camshaft JPY24,000yen.Regrinding cost JPY60,500yen.Profile making cost JPY50,000yen.
Custom-made cams TOTAL JPY158,500yen.(about USD 1,340 dollar)*********************************
RegrettablyIn case of Custom-made cams, we can not provide it for you as CAMSHAFT KIT.
Custom-made cams TOTAL JPY158,500yen.(about USD 1,340 dollar) [#1009M-N007]
Racing valve spring JPY24,000yen.(about USD 203 dollar)
If you have a further enquiry please contact us.
We are looking forward to hearing from you soon.
Regards,JUN Auto Japan[/quote]
