StarPD »
https://forums.nicoclub.com/starpd-u54244.html
Fri May 16, 2008 8:35 am
We often see redundant questions regarding simple problems by new owners of Q45s here. Some might be laughable, but they aren't funny to the guy who just dropped hard-earned cash on what he thought was a really nice car. "Wow, what a cool car. I can buy it for $3,000 and be stylin', and the chicks will dig me". Well, partially true. Unfortunately, the $3,000 is only the beginning.
There are already "stickies" on this, but repetition seems to be necessary, as the many posts asking the same questions by new owners are evidence that too many completely overlook them. So here they are for those who missed the stickies:
Despite repeated warnings here in this forum, many new and prospective buyers overlook the realities of getting a new Q. There are some things that if ignored, WILL cost you a LOT more money than you bargained for, and there are some things that are essential for enjoying your investment, and to keep you from spending far more than might otherwise be necessary.
First off, before you plunk down your geetahs, you MUST get all maintenance records on the car from day one of it's life. Secondly, you need to have an experienced Infiniti SENIOR technician inspect it to determine which items need attention. Hint: Buying him a case or fifth of what he drinks, a box of his favorite cigars or carton of his favorite cigarettes is a wise investment, cheap at any price, BEFORE he begins his examination.
Then, once you've determined what your new baby needs to bring it up to snuff, as Q45tech says, usually at least $3,000 or more, there are things you need to do to protect and prolong the life of your investment.Absolutes are:*Complete FLUSHES (or at least complete replacement) of ALL fluids. That means engine oil, transmission fluid, cooling system, brake system, steering system, and even differential, and fan fluid on those vehicles that use fans with replaceable fluid.*Replacement of ALL filters with either OEM or other premium ones.*4 wheel alignment*Replacement of W/S wiper blades*Cleaning of radiator and A/C condenser coils, heater and A/C evaporator coils*Cleaning of PCV valve and MAF
Probables, or at least possibles are:*Replacement of all suspension and steering rubber bushings, motor and transmission mounts and exhaust hangers*Replacement of shocks and struts, tension rods, and other steering/suspension components*Radiator, alternator, water pump, PS pump, starter, A/C compressor or clutch*Hood struts*Correct aiming of headlamps*Sunroof components, window/door switches and motors, power antenna*Brake master cylinder and calipers, pads and even hoses*ALL hoses and belts (should at least be checked)*Spark plugs and valve cover gaskets*Don't forget tires. Even ones with plenty of tread may be aged and vulnerable to failure.
These things all presume that the engine and driveline are all standup, and that engine passes compression and leakdown tests and oil pressure (hot) is within limits, and that the transmission shifts smoothly and positively hot and cold in all gears, and there are no undue vibrations at any speed in any gear. If not, run, don't walk away from the vehicle. There are plenty of others available that ARE good and worth refurbishing.
If they are all good, plan on doing everything the senior tech recommends, and get estimates for whatever it takes to bring it up to safe and reliable condition. 3 to 6,000 dollars is not an unreasonable amount to spend to resurrect a good solid Q that needs TLC to get the most and best out of it. Start the car out right, and it will reward you with years of enjoyable, safe, and reliable driving. Once properly refurbished, there are few other cars that are as enjoyable as a Q45, even the older ones.
Those who ignore this advice will be obvious by their presence here and in IOM. And yes, we'll still help you, even if you didn't pay attention here.
