For guys on the fence about GM LSX motors and their potential
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
JustinStrife
Car: '99 FRC. 402, Vortech T-Trim @ 12psi = 706rwhp/621rwtq
I bought my 2000 Corvette with 108k on the odometer in early 2007 from a friend. He had just finished installing a Procharger D1SC Supercharger two months before. The car made 480rwhp, 450rwtq @ 8psi on a conservative tune with only LG longtube headers as the only other power mod. The picture taken is just when I got off my lazy butt and took pictures.
At 118k I lost an idler pulley on the supercharger due to the bearings wearing out(my friend had bought a used supercharger kit that had 6k miles prior to being installed on this car). This is the only failure I've had in 16k miles and over 30 months of ownership(it's been my daily driver). Fortunately I was only 30 or so miles from home but it still sucked.
At just shy of 124k miles, I had the Cartek Flip-Drive and water/methanol injection system installed then had the car retuned @ RPM Motors in Santa Clarita. Again, I requested a safe tune as I've never been one to baby my cars. I did these mods more for reliability sake, but knew I would pick up some more power due to added boost from the flip drive, and higher octane from 100% meth.
Somehow the original clutch is still hanging on too, then again I don't do burn-outs so that might have something to do with it. Most of my driving is canyon carving or desert back roads chasing after Z06s, ZR1s and other Supercharged C5s.
The point to my thread, is to educate people about how strong the stock engine really is. Dozens if not hundreds of LS owners, have hit well over 600rwhp(several have hit over 700!) on pump gas once they're willing to start digging into the heads/cam/intake manifold. Granted, we can't run 20+ psi of boost on the stock pistons and our compression ratios are much higher(10.1:1 on LS1s and 10.5:1 on LS6s), but these motors respond extremely well to boost, whether it's through turbos or superchargers. If you're willing to leave the engine stock and not beat on it every chance you get, 300k miles isn't out of the question. A friend of mine just hit 100k miles on his 2007 C6 Z06 Sunday with the only problem being a bad oil pressure sending unit at 96k miles.
Hopefully this wasn't a wasted click, and happy modding.
Modified by JustinStrife at 12:53 AM 2/10/2010
HurryupandrunS13
Car: 1992 240 fastback
Im lovin your torque curve!!! That is the exact reason I'm wantin that for my duece. Congrats on the Vette too
JustinStrife
HurryupandrunS13 wrote:Im lovin your torque curve!!! That is the exact reason I'm wantin that for my duece. Congrats on the Vette too
There was a turbocharged LS1 S13 coupe at one of the local car shows here last year. 540rwhp @ 10psi bone stock LS1.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Justin, your car is win.
JustinStrife
l0nestar wrote:Justin, your car is win.
Thank you lonestar. I think it has a long way to go before it can be win. But it's all worth it when everything works.
kyhunter89
Car: 1989 240sx 5 speed
i've seen stock bottom end (arp rod bolts) 4.8's hit 850 hp
WDRacing
At this point only ignorant people don't respect the entire LSx line...the whole line is full of win.
85 720
I think only diehard Ford fans as well as die hard import haters would say GM's LS line is crap. GM may have many problems, but one thing they can build is a solid V8.
Return to “Hybrids”
