c-rad »
https://forums.nicoclub.com/c-rad-u19918.html
Fri Aug 18, 2006 11:21 am
To set TDC, you want to line the second marking from the left on the crank pulley with the indicator on the lower timing cover. Or, the poor man's way is to put a screwdriver into the cyl#1 spark plug hole and watch for it to reach its peak height while rotating the crankshaft.
