Chingon »
https://forums.nicoclub.com/chingon-u8507.html
Fri Aug 14, 2009 7:57 pm
hehe, weird how people think the same thing at around the same time.
I've actually been looking into it pretty intensly. You get 200 hp w/v-spec trim, a fully counter-balanced crank, and I believe w/the new revisions forged rods, forged crank, and better pistons (don't quote me on that).
The way I've sorted it out is like this:
QR25 from 2007+ v-spec sentra: fixed catalytic problem, fixed 2ndary butterfly bolts problem, i think revised block, and maybe removed rotating shaft (balancers) mechanism. Not to mention increased compression for moe powah...
Frontier transmission or bellhousing (transmission is actually the same one found in the z32, z31 turbo, among others (you get the "upgraded transmission everyone wants in their crazy ka setups).
Intake manifold cut at the output ports, reversed, and welded, or Mock up sr20 greddy manifold (the ports seem to have similar shape but spacing must be checked.)) The last method will obviously get rid of the 2ndary butterflies so you'd suffer some torque losses in the lower rpm and require standalone from it most likely. The other option is to run the intake ala 350z from the firewall to the front.
mechanial throttle body (i think the ka's may fit from bolt pattern).
Frontier engine mount brackets and insulators: They are very similar to ka mounts and perhaps line up enough (the ka mounts may work fine too), and the design of the insulators is similar enough.
Downpipe... you may try to use the frontier one and see how that works, but more than likely need to fab one.
Driveshaft: The z31 turbo transmission allows the use of the stock KA driveshaft. If that's the case and the z31 transmission is identical in length to the frontier transmission, then a z31 driveshaf may be the ticket. Otherwise, you'd have to buy the z31 transmission, swap bellhousings and your set. This however may compromise the position of the engine w/respect to the firewall.
Flywheel and clutch: QR flywheel and clutch, nissan uses same input shaft in many transmission models so I think the posibilities for clutch setups is limitless.
ECU: this is the big one, you could use the sentra spec v QR ecu which will net you the 200 hp if installed correctly. However, as we've seen w/the 350 setups, you have to get the pedal/position sensor combo, plus anti-theft system (porbably includes having to take the ignition cylilnder and key). I am unaware right now if there are people out there that may be able to delete this last requirement off the ecu. I've also read around that early QR did not have the nats/anti-theft setup, however it's doubtful that such ECU would work correctly w/the newer QR's.
Frontier ECU: A possiblity that allows you to use a rwd harness, however, the QR in the frontiers is that of the older QR revision, so perhaps won't work or output the same power in a sentr spec V QR.
Harness: Altima, sentra, frontier. 1st 2 undoubtedly needing modification.
Megasquirt: i think the last iteration allows you to control electronic throttle bodies...you may say, just ditch the damn thing, but I also believe the new MS has provisions for launch control....so electronic tb, ABS in 240 would perhaps net you a neat traction control setup.
KA ECU or SR ECU: Now before you call me crazy, i've seen KA's run on DSM ecu's, so bare (sp*) w/me a minute. I think there's been some crazy advances in the KA cracking side of things so if you use the ka harness and sensors (which may or may not be the same in/the QR, there very well could be a possiblity here. The big one is spark however since the QR has COP ignition (don't know if cracks allows KA's to run COP), which tells me the SR ECU may be best suited.
Still with me? Let's talk turbo:QR aftermarket is there in turbo form. The QR turbo manifolds (both log and equal length setups) are pretty symmetrical and lend themselves nicely for rwd purposes. The older QR manifolds which had the defective cat-back are of a nice design as well, and I beieve may be modified for a cool bottom mount setup. The rest well, it's pretty much the same as any other engine.
Spec-v engine could very well be turbocharged in its high comp. form, but there's the cheaper '07+ QR w/175 hp found in altimas and base sentras. You still get all the new revisions, but a lower compression ratio. You may even be able to pull off some other ratios using older QR pistons.
It's a nice engine in its newest form. I've been thinking of making some parts to get this done, but being pioneer is a bit risky. Don't let the naysayers bring down the concept....it wasn't that long ago that turbo KA's where considered a waste of time. Think about it, more displacement than a KA, an SR redline, and 100 lbs lighter than an NA SR engine!! W/turbo you are talking about NA SR weight. There's pros in that it's a newer engine, open deck (better cooling weaker in the boost department), lends nicely to light-weight car setups as well as NA setups and is probably legal under SCCA mandates.
Now, I've probably let the cat out of the bag, but it could help in gauging interest.
