gbaz77 »
https://forums.nicoclub.com/gbaz77-u38907.html
Mon Aug 07, 2006 5:31 am
i recently installed an RB20det into a 90 240sx. from what i gathered, the tach wont work regardless of the resistor trick (correct me if im wrong). anyway, basically everything worked except for the tach. and if you guys get that far, instead of sending your cluster into LS auto, go to your nearest junkyard and either buy a gauge cluster for a maxima, or just dissasemble one and take the tach unit. it reinstalls very easily, just unscrew the tach unit from behind the gauge face, and rescrew into stock 240 cluster. works perfectly without a resistor, all it will need is slight calibration due to the fact that you need to remove your tach needle from the stock tach unit and reinstall into the maxima tach unit. this is save you tons of money, and all that shipping time!!
i can do a write up if anyone wants, but this is pretty untechnical so let me know.
gamay
