rjdmmfl1 »
https://forums.nicoclub.com/rjdmmfl1-u77059.html
Thu Apr 10, 2008 4:38 am
yeah if you go to search at the top and put in footwell... two links will come up.... all information you need is there!
regarding pulsing to music, you simply need to keep the control module attached when you set up your system. I took that off because it is annoying. The way its designed, you have to physically push the on button on the module everytime you get in the car.
The way I set mine up, I can leave my oznium switch in the on position, then whenever I turn the car on, the LED lights turn on automatically, and when I turn the car off, the LED light automatically turn off... and then I can control it further by flippping the on/off switch with the car on!
do the search, follow the links, and the information as to where we purchased our lights and switch is all there!
