BrandAidDesignG35 »
https://forums.nicoclub.com/brandaiddesigng35-u84960.html
Tue Jan 13, 2009 6:34 am
Hey, welcome to Nico, just a few questions.
How many miles on your G, Have you manually checked your tire pressure? If not, check the pressure to make sure the TPS is reading accurately... if it's not, and going on for no reason, I would replace the sensor.
If your car was in an accident, it may be possible that the trunk latch is sticking or caught on the release mechanism. I would oil/ lube the area, and make sure your safety lock is not activated in the glove compartment.
Driving in snow will take great patience with the G. If you have your VDC off, you will be more likely to lose traction, but more likely to maintain tire rotation.
With VDC on, the computer will kill the throttle with the first slip of a tire. It will cause you to come to a stop in snow. Keeping VDC off will ensure you can keep the tires spinning, just enough to keep your momentum.
Ideally, you'll need winter tires to curb this issue, I choose not to drive my G in the snow period, unless it's for a quick series of donuts in the snow for fun.
Your tire's lifetime will depend on your choice of rubber, driving style, etc. I think you have made some poor assumptions regarding the G, and hopefully you will have improved luck in the future. I too have had no problems really, all things considered, the G is a solid car that keeps improving each year.
