ride4lame »
https://forums.nicoclub.com/ride4lame-u937.html
Fri Dec 05, 2003 11:24 am
If it has the spoiler, lift it up slightly, you will see most likely that there are rust holes under the spoiler, so you will need a new one from a junkyard.
If there is no spoiler, then loosen up the bracket that holds the whole hatch and it may shift alittle bit. Or you need a new rubber seal that goes around it.
