Foglights for 2007 2.0 sentra
bakerboard
Car: 2007 Nissan Sentra S 2.0
Does anyone recognize these foglights?? I found them on cardomain and i really like them but i dont know what company makes them..
Faja
Car: 2009 Nissan Sentra
They kinda look like Autopia but not 100% sure. Check their website http://autopialighting.com/
bakerboard
ok now my question is
are the se-r foglights the same size and all as the base model ones?
because the autopia ones only work for the 07+ se-r
Faja
They have ones for the Base and S models
http://cgi.ebay.com/ebaymotors...ories
Faja
If you want some advice, go with these instead as they come with everything to mount the lights properly onto the bumper. These look just like the OEM fogs. They might not have the fancy halos but they will definitely look better on your car.
bakerboard
ok thanks for the links. I appreciate it . ill decide on which ones to get. The OEM looking ones look a lot easier to install though.
bakerboard
I went ahead and bought the OEM looking ones. I was thinking of installing them myself. Is it hard to install foglights if you dont really know what youre doing? these foglights do not come with instructions, so i have nothing to go off. If someone who is good with foglights, can you post some step by step details on how to install them? If not i guess i can take it to nissan but i would rather save the money and do it myself.
Faja
Hold on Bakerboard, I have to go out now but later tonite I'll post up instructions for you. In the meantime, can you take pics of the set you got, I need to know every single part of the kit and I'll tell you how to hook them up.
I need pics of the following:
Wiring harnessFuseRelaySwitchLamp assemblies
bakerboard
Well i just ordered them. The only way to pay was with paypal. So i transfered money to paypal but that wont be confirmed till the 30th and then it takes 1-6 business days to ship. So i wont have pictures for about a week or two.
Faja
OK, no worries In the meantime I'll check the website and see if I can get all the relevant info....
bakerboard
Ok cool, if you find pictures post those up too!! please
Faja
Who did you order it from? Sabersport??
bakerboard
yes from sabersport
Faja
Hey Bakerboard, I sent an email to sabersport and the kit comes with light assemblies, wiring harness, bumper brackets and switch. To hook it up properly and safely, you will need to buy 1 automotive relay (4 pin) and one inline fuse holder with 30A Fuse and 12-14 gauge wire on each side of the fuse holder. Make sure you have about 1-2' of wire on each end of the fuse holder. You should also pick up a pack of spade connectors and a couple of ring connectors for battery and grounding and if you don't have a wire cutter/crimper see if you can either borrow or buy one. I will post up some pics so you'll know exactly what I'm talking about in case you're not familiar with it. The relay, fuse/holder and terminals should be around $15 total. Let me know when you get the kit and post up pics of all the pieces.
thanks
bakerboard
I know some of the stuff you are talking about. My brother is more inclind than i am and he is oging to help me set it up so he prolly knows what your talking about. Thanks so much for the help so far!
ABNRML4U
Car: Nissan B13
Can't wait to see before and after pictures of these foglights.
bakerboard
Foglights should be coming in soon! Hope to install them today but we will see. Faja what would you like me to do when they come in? do you want a picture of everything that came? I still need to go out and buy those few things that you told me to buy.
bakerboard
They came in! here is the photo of everyting that came.
Are you sure im going to need the stuff you wanted me to get?
Faja
If you're going to hook it up to the factory wiring, then you'll just need to replace your light switch stalk with one that has the fog light option on it. With the factory wiring your low beams must be on for the fogs to work. If you want to be able to turn on/off your fogs anytime you want and work independently of any other lights, then you have to run wires and switch that came with the kit plus add the relay and fuse we discussed earlier. Let me know which way you want to go before buying anything.
PS: I can't maximize the picture either!!
bakerboard
I wont mind if both low beams and foglights have to be on but i also dont want to pay $150 for nissan to replace the stalk and hook up the foglights! SO if i have to ill go buy those this for it to work independently
Modified by bakerboard at 4:57 PM 10/6/2009
bakerboard
The only thing is though. It looks like everything is here for the foglights to work from the swicth.. here are some photos of the insturctions
Faja
The wiring harness is all bundled up so I can't see it properly but if you have a relay and fuse already attached to the wires then you don't need to buy anything. It looks like the fuse is attached on the red wire and the relay might be down about a foot from the red wire also?? Let me know if that's it. If that is the case, the diagram that they gave you seems pretty clear, the only difficult part it trying to run the wire from the engine bay to the inside dash. If you take out the air filter box, you should see some wires going to a grommet on the firewall, you can use a wire hangar and try to push it thru' there but be careful not to cut into any existing wires, the other side will come out near the brake pedal and from there you can run your switch. Also remove the ground terminal from the battery before doing any electrical work. See if you can figure it out from the pictures, and if you need any additional help let me know. I will post up some pictures of how I did mine for you tonite.
bakerboard
Yea im pretty sure there is a relay and yes there is a fuse
this is it correct?
Faja
That's great, you don't have to buy anything else. Just follow the diagram and you're all set. Here are some images
This is where wire comes out close to the brake pedalI put in an "Add a circuit" to the top right slot in the fusebox and ran power wire there so in case I left the switch on, it would turn off with the ignitionThis is where I put the relay and wires from the fogs, hidden under that support beam with the twist tieHere are my switches, there are illuminated, I have two as there is another LED bulb in the fog light like a small park lightHere is where you run the wire thru the firewallPICS of the Fogs:LEDDaytime NighttimeHere are some other images , one of VG Shark Fin and a reverse camera/monitor that I installed
Modified by Faja at 9:11 PM 10/6/2009
bakerboard
Ok cool. That is great to hear.. THanks for all your help. Your car looks great with the fogs too!
Faja
If you run into any issues, let me know. Don't forget disconnect battery before starting!!
bakerboard
Haha i will. Its the first thing im going to do! Ill let you know how it turns out. Im going to work on it saturday.
bakerboard
i cant get that swicth wire through the wire firewall. If i can take the air filitr box off it would be easier to get to. how do i take off the air filter box?
edit: also my car is pre-wired for fog lights. could i use that wire and just run my swicth to the inside of my car? here is the picture of the wire for the foglights....
( its the yellow looking male connector )
Modified by bakerboard at 5:46 PM 10/11/2009
bakerboard
Anyone know how to take the air filter box off?
Also is it hard to change the light swicth stalk if I go with the factory wiring? Or should I ask Nissan to do it?
Modified by bakerboard at 9:51 PM 10/11/2009
nametakennow
Car: '06 MINI Cooper S
What you're seeing under the driver's headlight is the resonator box, I believe, not the air filter. It should have some sort of connection to the part you can see inside the engine bay. Pop off the connection up top and then pull it out through the bottom.
