Foglight wiring harness
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
VersaMG08
Car: '10 Mazda 3 s hatchback
'14 Nissan 370z
Couldn't find the foglight installation thread anywhere on NICO so I made a new thread.
I recently checked under the hood for the wiring harness to see if my SL was prewired which it is. My other question I have is, where is the other wiring harness for the left and right foglights connections? If there are two connectors, do you just pull on the wire harness and it releases slack from it being taped inside the engine bay? Any help is appreciated!
dee_tymz_sl
Car: 2007 Nissan Versa SL Sedan
VersaMG08 wrote:Couldn't find the foglight installation thread anywhere on NICO so I made a new thread.
Check this link, maybe this will answer your question...
http://forums.nissanversa.org/zerothread/428193
While digging in the hood of the car, those set of wires I found on the passenger side... I found the other set of wires on the other side of the car. I hope that could've help answer your question and good luck.
VersaMG08
'14 Nissan 370z
Are the wires going to be long enough to connect into the left and right foglights bezzles? Are they taped in the engine bay?
dee_tymz_sl
Yes, the wires should be long enough because when I looked at them they were wrapped up so there shouldn't be any problems there. Besides I'm sure if it weren't someone would've probably b****ed about that by now...
VersaMG08
'14 Nissan 370z
Thank you! I'm so glad I bought the foglight kit, this will help out alot at night and during a rainy day.
dee_tymz_sl
I planned on installing a set as well and that's why I started asking around and digging through the hood to find them.
Post some pics before and after so we can see what it looks like..
Codelicious
Car: 1989 Nissan 240SX
Does anyone know if all SL Versa's are prewired for fogs?
I saw the thread about where to look but I couldn't find anything or I'm just retarded.Hopefully they are, or at least hopefully mine is. I want fogs but don't want to spend $$$ for all that crap that should already be on the car! lol
VersaMG08
'14 Nissan 370z
Codelicious wrote:Does anyone know if all SL Versa's are prewired for fogs?
All the SL's are prewired. You shouldn't have to bother looking.
dee_tymz_sl
Yes I've done a thread on this and yes apparently all the SL are pre-wired for fogs. Check the link...http://forums.nissanversa.org/zerothread?id=428193
Return to “Versa Technical Discussions”
