Foglight fuse wiring (QX56 2010)
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
Mitchsky
Car: 2010 Infiniti QX56
My foglights stopped working. I couldn't find the fuse, so I checked them 1 by 1. I tried changing the bulbs. Going through the fuses at the IPDM I found a loose wire with a blade connector and the end just hanging there. I stuck it in a nearby small hole and now the lights work! At the other end is a sideways fuse connector going into another fuse slot. Is this a normal wiring for this, or is this something that somebody else did as a fix?
I have a picture but don't know how to attach it.
Return to “Armada Forum / QX56 Forum / QX80 Forum”
