Depending on what those were, maybe.mbock76 wrote:So it seems every night I drive home my winshield constantly fogs up. Before you say anything.....yes I put defroster, ac, heat, opened the window, you name it i tried it. The friggin thing just keeps fogging up. The other day I was driving and two plastic pieces flew off my car from somewhere could this be what is causing it?
I had a Ford that was doing this once and it turned out the drains from the air intake for the ventilation had plugged up. Movement from the car would slosh a little water over the edge on to the heater element and the windshield would instantly fog up.mbock76 wrote:So it seems every night I drive home my winshield constantly fogs up. Before you say anything.....yes I put defroster, ac, heat, opened the window, you name it i tried it. The friggin thing just keeps fogging up. The other day I was driving and two plastic pieces flew off my car from somewhere could this be what is causing it?
It is not unusual for a new car with lots of plastic to 'gas off', especially during warmer weather. Clean the windshield with diluted ammonia/water using a wet rag, be a little carefull about getting on something like the headliner or carpet. I would go with as strong a solution as your nose can handle. This will cut the film.Graflo wrote:I was going to make the same post.... Nothing flew off my G but I always have this wave of fog creeping up and down constantly. I notice it more around sunset. Same as you windows up, down, cracked, with defroster on, off, different temps Hi and Lo.... even tried with sunroof open cracked... nothing helps. I have not cleaned the inside window but I only have 5K on the car.
I guess I will try that next. Any other suggestions?
You didn't mention whether it fogs up on the inside or outside?mbock76 wrote:So it seems every night I drive home my winshield constantly fogs up. Before you say anything.....yes I put defroster, ac, heat, opened the window, you name it i tried it. The friggin thing just keeps fogging up. The other day I was driving and two plastic pieces flew off my car from somewhere could this be what is causing it?
