Foggy headlights
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
cfschreib
Car: 2004 Infiniti G35 coupe
I have a 2004 G35 coupe, the plastic enclosure for the headlights is getting very "foggy". Does anyone have a solution?
joe603
Car: 2014 Durango R/T
Try a good plastic polish like Plastic X to clean the outside of the headlights. Most likely, your problem is on the outside unless you have a crack.
pae9132
Car: Modified 03 V35
i have an 03 and i've had this problem for a while...i've used the different brands of plastic polish but they always seem to get foggy again...i'm going to have a body shop do a professional polish and apply a seal over them
BATComm1
Car: 2004 Infiniti G35 Sedan
Our 04 had the same problem..this is how I fixed it..I took 1000 grit wet/dry sandpaper and keep it wet with a spray bottle (Water) and I sanded both lenses till, when wiped dry, I couldnt see anymore yellowing and the lenses were "scuffed" ..then I used Meguires "Plas-X" ( White bottle at Wal-Mart ) and my high speed buffer and buffed the lenses back out then used the Mequires plastic polish ( Black bottle ) and buffed again..total process about 45 minutes and the lenses look brand new...
joe603
That's a bit extreme...plastic-X should be all you need.
Return to “G35 and G37 Interior, Exterior and Audio”
