KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Sat Jan 07, 2006 6:34 pm
Recent dyno testing here in Knoxville showed a gain of approx. 14whp using an NOS intercooler sprayer. If I were spending the money on a nitrous kit and on N2O itself, I'd want more than 14whp.
Now, you can use the N2O on your forced induction car without any troubles. NOS offers a kit (Part #0031NOS) to convert your system to a wet kit, which is vital when you go forced induction.
So, for now, you can run the kit dry while you're N/A. Then, when you go F/I, order the kit (it's about $125.00) and spray a wet 50 shot.
The reason you can't go dry on a F/I car is because of the design of the fuel management used on the kit. It utilizes a vacuum tee with a restrictor (should be a replacable jet) interrupting the fuel pressure regulator vac. hose. As the nitrous pressure comes, it increases the pressure at the FPR (via a nitrous pressure regulator between the solenoids), thus increasing fuel spray through the injectors. The design of this system requires somewhere for the excess pressure (air pressure, not fuel) to bleed off (back into the manifold). Once you're F/I, you can't bleed the pressure back into the manifold vacuum supply because it's at X psi.
Trying to run the kit dry with this setup on a F/I results in fuel pressure around 120+psi, preventing the injectors from pulling open, thus resulting in a lean condition and blowing your mill.
The only way to run a dry kit on a F/I application is to hack the MAF, run it blow-through, and spray the dry shot pre-MAF, post turbo.
I say run it, then convert it, then be smiling when you spray it.
