jmess wrote:I assume you have the climate control on auto and the recirculating air light/button isn't on?
Correct.
jmess wrote:I guess it is also possible your AC isn't cycling at higher speeds, this could be a sensor defect.
I think it's operating normally. We often turn off the AC when it gets really cold out. If I use the Recirculating Button, then I make sure the AC is on, so that the air-flow doesn't fog up the Windshield.
jmess wrote:What happens when you push the front windshield defrost button? That should increase defrost to the front windshield.
Fan Speed goes to maximum and all the other Vents (I think) close off.
