fog lights
All things Altima Coupe.
xero1
Car: 08 Altima Coupe
Is there space for a aftermarket fog light bracket to mount?
http://cgi.ebay.com/ebaymotors...ories
Blackmobile
Car: 2008 Altima Coupe 2.5S Super Black
Negatory, i bought these lights and i'd recommend you stay away. They don't fit. The fog light hole on the bumper is about 3" wide and those fogs are over 4" in diameter. On top of that, you'll have to find some way to make your own mounting bracket, these will not fit the original mounting bracket. I ended up bending the bracket it came with to make it fit, and now they point downwards. AND... to top it all off, after installing them about a week later there's condensation inside the lamps...
xero1
What about these fog lights, they look just like the oem. Will they fit like oem foglights?
phobs
Those look good to go for aftermarket ones. Make sure you use the 30% ebay cashback, that'll save you a good amount for those :D
Blackmobile
As far as i know, yes those ones will fit just like OEM's, however they won't be plug 'n play, you'll have to run the wiring from the lights to the battery and install a switch in the dashboard through the firewall. Butter than the autopia light though. also that auction is for the lamps only, i believe i've seen an auction from the same seller that also includes the wiring and switch.
xero1
phobs wrote:Those look good to go for aftermarket ones. Make sure you use the 30% ebay cashback, that'll save you a good amount for those :D
how do i get 30% cash back? is there any other aftermarket fog light that fits good?
phobs
To get cashback you gotta sign up for a live account. The process seems long and sketchy but I've bought many things and its totally worth it.
http://www.spoofee.com/forums/...25345
As for the aftermarket fogs, the ones you posted earlier seems to be the best fitment ones since they are OEM aftermarket replacement.
zigggy56
Forget the OEM CRAP..... Get creative
vonivo
Car: Altima Coupe 3.5 with all the goodies
zigggy56 wrote:Forget the OEM CRAP..... Get creative
it doesn't look that bad but the factory mounted ones look alot better but you did a decent job mounting them...are they level and straight?
Rmuth25
Car: 08 Altima Coupe 2.5s CVT [Premium & Tech Packages]
Reminds me of something you would see on a truck/jeep. Interesting though for sure.
zigggy56
Nothing is going to look as good as factory, however OEM fogs are pretty useless. Yes these are very straight, level, and extremely blinding (they are PIAA HID) got a great deal on them from amazon, paid less than half of retail.
