?? FOG LIGHTS ??
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
SaLsa_VerSa
Car: 2008 Nissan Versa
hey everyone what do u think about gettin Fog lights from Walmart?...just curious cuz i was in walmart yesterday with my wife and of course i walk through the car section and i saw fog lights....so i was thinking if it would work/look fine on the versa..
any suggestions?.....
srellim234
Car: 2007 Nissan Versa SL hatch w/CVT
(sold 08/2011)
2008 Toyota Prius
(purchased 04/2016)
SaLsa_VerSa
THNX HELLPED ALOT
alex_btl
Car: Versa SL HB/QUEST SE
Does any one know the output Wattage of the factory Fogs. It would be better to buy an Aftermarket Fog light with the same outputso that it wont overheat or blow anything up
would anybody agree?
SuperTurbo
alex_btl wrote:Does any one know the output Wattage of the factory Fogs. It would be better to buy an Aftermarket Fog light with the same outputso that it wont overheat or blow anything up
Actually.... I am thinking something which sounds quite weird.... (So don't flame me)
Locate the regular headlight unit as a fog light, and use those fog light wire to power the HID.
Advantage: way brighter, and you save the halogen set, for sure that fog light wire is more than enough to power a set of HID (35-55W for HID, right?)
Disadvantage: how to do the wiring. (I mean... low & high beam on that set of HID + Halogen), will halogen melt the bumper.
If I can have 2 individual control of the high low beam + on/off, it will be amazing.
zilvia_brothers
Car: 1987 200sx 5-spd V6
quick question about the OEM fogs. i've read that the SL trim is already pre-wired for the fogs. So how about the S model? i have an S and im thinking about getting the fog lights but not sure about the wiring
SaLsa_VerSa
well i also have the S model...and i've searched for the wires for the Fogs...I dont think they come preWired on the S....only SL....so i guess we need to follow the tutorials up above to install fogs ourselves or take it to a tunershop...
Wish we had it preWired...much freakin easier....
GracelandII
Car: 2011 Nissan Versa S
Sorry to resurrect such an old post but I came across it today. The pics helped me locate my plugs today after 2 failed attempts. I have a 2011 S with the power package, so this option does come prewired from the factory.
Francesco
My 2009 Versa S sedan was prewired, however it came with the Power Package, Cruise Control, and ABS. I believe the important item is the power package in order to have it prewired.
Frank Versa S sedan MT-6 with 16150 mi
Return to “Versa Technical Discussions”
