fog lights
kcourtad
Car: 2007 Nissan Versa SL Sedan
im thinking about putting some fog lights on my V but im not spending the $300.00 ones that the dealer**** has for the V... any one have any pic`s of theres with some fog lights on them and tell me how hard was it to install ?
xtwoonamatchx
I got the ones from Autopia Lighting off of ebay... theyre really good quality... install was fairly simple, make sure you have a decent amount of wire ties... i got a pack of 100 at homedepot for a couple bucks... like with a max diameter of less than an inch (forget the exact number) but they do fine.
engine bay with all the wiring...
on.
off...i really messed up the finisher when cutting it, well my friend did... versaspeed has the already cut ones for sale...
install was fairly easy.. no cutting or splicing... i mounted my relay to a screw holding up a white/black box thing in the far right of the engine bay (dunno what it is). grounded to the screw kinda near the headlight asyou can see. They come with a switch but i didnt use it, i wired into the running light (for the relay) and the power is just put onto the battery terminal. If you get them, let me know and ill go more in depth with you of my install.
you can email me at [email protected] if you need any more help...
i personally think, next to OEM, these look the best.
http://cgi.ebay.com/ebaymotors...ZWD1V
those are the ones i got
