Fog Lights
Discussion forum for body kits, repair, modifications, interior styling, Audio / Video and internal/external lighting.
SteveCooper
Hey Guys & Gals
i am thinking of changing the bulbs of my Fog Lights in my G35 Coupe and i wanted to know what bulb type would i need.
I was thinking of getting some of those bulbs with the Blue tint on them or somthing that will give the blue or white look beside the regular color
can someone help me on this
BillR
Car: Offshore boating, cars, electronics
H4 bulbs. I got mine w/ a bult tint, they "tend" to match the low beams.
SteveCooper
So H4 Bulbs for the Fog Lights?
Super Dave
If you buy new bulbs for your car, I would suggest PIAA brand bulbs. I know my car products pretty well, and I wouldn't waste my time with the cheap crap. You can probably get a set that will suit your needs for about $80 on ebay. Typically, you could get similar blue H4's for about $20........I've owned both, and the PIAAs are worth the price increase.
SteveCooper
How do i install the bulb for the fog lights.
i can not get behinf the headlights to install them.
how do take the headlights off the car so i can install my new bulbs
i am lost
:help :confused: :help :confused: :help :confused: :help :confused:
Super Dave
Anyone ever considered putting bright yellow bulbs in to replace the fog lights. I think it might have a really cool effect of contrasting the HID. I plan on doing it to my G35c when it gets here. If any of you decide to steal my idea let me know how it works. Also, I'm not a fan of cheap replacement bulbs....I'm a big fan of PIAA, but I don't theink they make a yellow H4 <---what i heard the fog bulb was. Does anyone, now of another good brand that actually makes this type of bulb.....Hella or something?? Let me know...
SteveCooper
Please can someone tell me how do i install new bulbs for my fog lights
please help
BillR
High beams / Fog lamps are h4.
try and have handy: flat head & Phillips screwdrivers, 10mm socket wrench, clean rag.
Remove the front wheel, To access the headlamps, you need to remove the plastic liner. There are push in tabs that lock the fender in place as well as bolts underneath the car to keep it from moving.
There are 3 tabs and 1 screw near the outer sidemarker, 2 behind the wheel, and 4/5 bolts underneath. There are another 2 push in tabs behind the wheel, but you wont be able to see them until you unscrew everything else first. To remove the tabs you just stick a flathead screwdriver into the slit and pop it up. After the fender is off you will see the back of the light assembly. There are 2 dust caps. The top one is for the HID Lowbeam, and the bottom one is for the H4 fog/highbeam. Unscrew the bottom cap and you will find the h4 bulb locked by a mechanism and 2 wires connected to it. Unconnect the wires by wiggling and pulling back, set them aside. Unlock the mechanism and the bulb should come out freely. Put in the new H4 light the same way the old one was in, re-lock the mechanism.Re-install everything. Should take about 15 min per side. Sounds complicated, but is really pretty simple. Once you get into it, everything necessary is obvious.
vkenny81
Car: 2008 Infiniti G35x AWD Sport
I would just put a brand new HID Kit in the fog lights. It does not have to be different color. You can get 4300k, 5000k, or at least try to match the stock Headlight HID. PIAA bulbs are fined. But HID is more reliable and consume less watts of which its good for your car electrical system.
Goat_Wiz
2010 Audi Q5 3.2
Ive been wanting to a get a HID kit for my fog lights. Any recommendations? I hate the yellow lights...
WESIDE
Car: 2006 g35 coupe
The type of bulb you need depends on the year of your ride. I think 06 and up is H-1 and 05 and older is H-4. Dont quote me on that. I just installed 4300k fog lamps made by piaa on my 2006 coupe. I cant remember the site I bought them from. But going to a more yellow color or lower kelvin spectrum bulb, will greatly increase your viewable distance in front of the car. I had piaa 6000k ?????? installed prior and they did have a more of a hyper white look to them but the lighting was noticibly more pronounced when I went with the 4300k yellow plasma ion bulbs made by piaa. Wes
Modified by WESIDE at 6:15 PM 12/8/2008
bat6wc
Car: 2008 G35xS
best fog bulbs i have ever had...Polarg Pure Yellow. very functional and stylish.
WESIDE
Car: 2006 g35 coupe
Just curious. What was the light rating on the Polarg bulbs?
bat6wc
Car: 2008 G35xS
WESIDE wrote:Just curious. What was the light rating on the Polarg bulbs?
here are the bulbs. i dont know what your size is though,
http://yhst-1408381693991.stor....html
Return to “G35 and G37 Interior, Exterior and Audio”
