How do I change the relay?KFL wrote:There is no fuse, just a relay in the fusebox. Should be labled on the fusebox cover engine bay compartment. Since both aren't working I'd look at the, fast/no clicking from relay its shot.
Sorry for asking so many questions on this, (never dealt with a relay before). The blue top is the part that comes out, is that the part i have to replace, or do I take out everything including the bottom white part.slydin’240 wrote:You should be able to just pull that puppy out and replace it with a new one. I picked all the relays out of one in the junkyard so I would have extras.
Just pull up and it will pop out, I forget exactly what the #is. You can compare the relay to the other ones if another matches the same #. You can try to swap and see if the relay is the problem.Nissan-S14 wrote:Sorry for asking so many questions on this, (never dealt with a relay before). The blue top is the part that comes out, is that the part i have to replace, or do I take out everything including the bottom white part.
Thanks I appriciate the info,
