matt1111 »
https://forums.nicoclub.com/matt1111-u122626.html
Fri Dec 19, 2008 2:21 pm
Hi, i want to change my combination switch near the steering wheel to the fog light feature as mine does not have fog lights but is pre wired for it, so if i want to turn the fog lights on i have to have the switch on the combination switch, at least i think so,
can you tell me if the 2007 altima 4dr switch will fit on 2008 altima coupe or does it change the specs.
also is there any way i can get fog lights that just plug in to the pre wired plugs?
I tried ebay there are some oem fog lights but not sure if they just plug in and work, plus they are $250 thank you
thank you
