ATXhttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=113&sid=62b793c6487eca59a6e3a31d81c2a3c9Fog lights for 2002 Q45Fri Mar 06, 2009 3:47 pm
Postby
seldomseen »
https://forums.nicoclub.com/seldomseen-u87252.htmlSat Jun 06, 2009 8:40 pm
Fogs only came standard on the '05/'06 model years. You best bet is to just get a quality aftermarket lamp that is oval shaped so it fills in the empty space as much as possible. You could also trying fitting the '05/'06 fogs into your '02, but the bezel will not fit unless you trim/cut it to fit.
