Fog lights don't work
red 300zx
Car: 1990 300zx n/a
When i push the button the little orange light comes on, but the fog lights don't any ideas? Also my low beams suck a** just saying.
robomatic12
Car: 1990 300ZX TT
Check fog light fuses/relays, check to see if you have power at the fog light connectors. You can access the connectors by pulling out the turn signals and then reaching inside to undo 3 10mm nuts which will remove the fog lamp assembly.
As for the low beams you might want to try a better bulb, sylvania silverstar is a good choice, or perhaps an HID kit is in your best interest.
