Fog lights/Dome lights not working!
praneel_s
Car: 1990 300ZX 2+2 N/A
2013 Altima Coupe 2.5S
So I did the Z1 35w --> 55w conversion on my fog lights the other day and the fog lights and dome lights both quit working. I haven't had a chance to check for blown fuses but I do know that it's a 30A fuse sitting in my fog light area and not a 10A.
When I installed them I did the RH (passenger) first, turned it on to make sure it worked, and it did sure enough. It was after I did the LH one that everything went kaput. Anybody ever run into this issue or know where to start?
PapaSmurf2k3
Site Admin
I'd check for fuses like you mentioned. If you're blowing a 30 amp fuse, that sounds excessive.
