Fog Lights... Can I?
A forum for the Nissan Armada, Infiniti QX56, and beginning in 2014, the Infiniti QX80
caufield25
Car: 2008 Nissan Pathfinder SE, 2008 Nissan Armada SE (R.I.P. 2008 - 2010. Totaled), 2005 Chevy Silverado LS
My Armada came without fog lights and in their place are thoes hideous black plastic knob looking thingys. I was going to install a set myself and i was going to wire them straight to the headlight wires so when they go on, the fog lights go on. That way i don't need a new switch and have to change a bunch of other things on the car. I first asked my dealer about the fog lights last month and they said that they couldn't install them because of all the things they would have to do to the car and that you can only get them from the factory with fog lights. So i figured, i dont need a switch for the fog lights... ill just wire them to the headlights. Is this an okay thing to do?
Timmbo
Car: 2013 Infiniti JX35 AWD
2013 Nissan Maxima Sport Pkg
caufield25 wrote:My Armada came without fog lights and in their place are thoes hideous black plastic knob looking thingys. I was going to install a set myself and i was going to wire them straight to the headlight wires so when they go on, the fog lights go on. That way i don't need a new switch and have to change a bunch of other things on the car. I first asked my dealer about the fog lights last month and they said that they couldn't install them because of all the things they would have to do to the car and that you can only get them from the factory with fog lights. So i figured, i dont need a switch for the fog lights... ill just wire them to the headlights. Is this an okay thing to do?
I would suggest placing them on their own switch. That way if you want them off, you can at least do that.
LibJunkie
Car: 2006 Infiniti m45, 2008 Nissan Armada
So Timmbo do you have any idea how extensive would this install be with the factory switches and lights. Aren't they already wired?
Timmbo
You know what you should do, is check the wiring in the Factory Service Manual. Here is a link:
http://www.nicoclub.com/FSM/armada/
TeKKiE
Car: '98 SE-R
When you order the lights, they come with the switch assembly, that replaces your current light switch. Install is about 5~10 minutes, with a screw driver and 10mm socket.
You need to be sure to order them with the correct switch (if you have auto headlamps, or not).
That's it! I got mine from GregV (www.gspec.com) for ~$150 shipped.
Timmbo
Sounds like a flawless install! Thank you for the update!
Return to “Armada Forum / QX56 Forum / QX80 Forum”
