musashin »
https://forums.nicoclub.com/musashin-u73801.html
Tue Dec 16, 2008 9:39 am
Alright so I bought some of those 'awesome' $20 fog lights from Advance Auto, and I've run into a problem. I've been trying to find a way to run the wire into the cabin so I can use the switch provided to turn them on and off, you know. But I can't find a good spot to run the wire through.
I've done some searching and found that you can run it through where the hood release cable comes through, but I can't seem to figure out how that works. Is there some way to pull back the seal around the hood release cable without tearing/breaking it?
As you can see, I've been trying to pull it back with my fingers, but I'm having trouble.
Also, how would I splice the power cable into the ACC part of my fuse box. I'm assuming if i splice it in there, I will have to have at least my driving lights on and then can flip the switch to turn the fogs on and off? Is there a better place to hook it up to?
