fog light swap went wrong
johnny_d
Car: 2008 Altima Coupe V6 SE w/ CVT
i guess i'm really stupid ...... aniway, I spent 2 and half hr trying to replace my fog light bulbs. Took a while cuz i didnt want to remove the wheel and stuff.. Aniway I finally found the opening at the bottom of the grill that I could slide my hand thru. Changed the bulb, first one ok, 2nd one was loose (maybe cuz the fiancee dropped the bulbs when she put the box on the washing machine and the thing just started spinning) Aniway, had to use a pair of pliers to adjust it so it'd be tight enough not to rattle in there. I could hear something rattling inside the bulb, not the glass but the plastic end. Plugged in the connector and the battery...........NOTHING. Swapped back to original bulbs (didnt drop those)......... STILL NOTHING...... headlights work (thank God). Wasted all that time and now the originals are screwed up too. I did disconnect the battery so I couldn't have shorted it. What could be the reason? Someone please shed some lights ... thanks
generic808
Car: '08 Infiniti G35 S
'10 Infiniti EX35
I don't quite fully understand what you're saying about the factory lights not working anymore and about something rattling in the bulb.
If your girl dropped the bulb, it's probably damaged. If not, maybe the connection is loose.
Also, did you check the prong connectors in the harness to make sure they're not misaligned?
johnny_d
it could be that the aftermarket ones are damaged, but I reinserted the original bulbs back and the foggies won't turn on. Completely off. I did check the connector, there's only 1 way to insert it and it clicked in
rjdmmfl1
Car: 2008 Altima Coupe, Radiant Silver, 3.5SE, Premium Package, VDC
Johhny, come down to San Diego tomorrow, and we'll take a look at it... did you get my email? Looks like there will be 5 of us... not too bad!!!!
johnny_d
haven't gotten ur email, bro. [email protected] ?
rjdmmfl1
yeah, i sent it about 10 minutes ago, check the SOCAL thread again if you can!
johnny_d
got it, my blackberry was low on battery that's why it didn't receive it
