Faja »
https://forums.nicoclub.com/faja-u129014.html
Fri May 15, 2009 3:30 pm
Hello JKing, the fog light relay probably only kicks in once the headlights are on plus the way the switch stalk is designed, you cannot turn the fog light switch unless the headlight portion is also turned. You could possibly try to trace all the wires and the relay and rewire to a new separate switch or it might just be easier to disconnect the foglight harness and run your own wiring, relay and switch to the existing fog lamps. If you need more details or information let me know.
