Fog Light Mod
cmkelly
Car: 1992 Nissan 240SX Vert
2006 Acura TL
2001 Nissan Pathfinder LE
1996 Toyota 4Runner 4x4
I saw this on another posters car and thought I'd document my process. Nothing original here. First I started with the most logical mounting place, in the vent area under the turn signals. Hope this doesn't affect brake cooling ;>)
cmkelly
2006 Acura TL
I picked some cheap lights from Advance/AutoZone. I mounted the light bracket to the vent itself.
cmkelly
2006 Acura TL
cmkelly
2006 Acura TL
Then I had to snake the wires to their correct locations...
cmkelly
2006 Acura TL
I used a coat hanger to get the wire threaded through the hole but had to slice the wire and add length as the wire that came with the lights was not long enough to make a clean run. I ended up having to splice twice; once for the lights and again for the control switch.
cmkelly
2006 Acura TL
The finished product will take some tweaking to sit right but you get the idea...
cmkelly
2006 Acura TL
The output was better than expected. You could also do the same mod with driving lights but you'd need to be careful where they are pointing so as not to blind your fellow drivers.
Good luck!
