fog light issues
All things Altima Coupe.
ronblac
Car: nisan altimacoupe
Need some help, i changed my foglights to hyper white 55w, same specs as the stocks, but when the head lights turn on, the fogs dont, so i put the orginal stocks ones back in and those too wont turn on either, i checked the fuse panel under the hood and by the drivers side the fuse is in tact, so i have no idea what i did wrong, can anyone help???????
DReed86
Car: Altima Coupe 2008 SE 3.5 White CVT
Your just hooking it up the new fogs to the stock bulb housing right??? Or are you splicing and doing some custom --ish??? Is the new bulb the right one? I cant remember 9h or 11h if I recall. Have you tried disconnecting the battery? Did you try turning the fog on by themselves??? There is a knob on the left stick I believe.
If non of that works just roll back to the dealership tell them to tell them to check why your lights arnt working... Sorry I dont have any other ideas.
ronblac
Yeah just replacing the stock fogs with what i thought was hid lights, thats all.....i didnt know about the left side switch or disconnecting the battery, i just took out the stock and put new ones, but i will try your advice, appreciate greatly bro......
do you know if anyone is selling a sway bar???
