Fog Light Issues
hiphopinstitute_com
Car: G35 2007
I want to know where the fuse is located for the fog lights and what number it is. Install some nice semi blue fog lights on my g35 2007 sport sedan and blow only after 30 days of use?
SneaKe
Car: 2006 Infiniti G35 6 ManTrans Coupe Ninja Turtle
Aftermarket bulbs have short lives, unless you purchase well established brands. If you touch the bulb with your fingers, this will shorten the life as well.
You have two fuse panels. One under the hood, next the the battery. You'll have to remove the batter cover and surrounding electrical cover to access.
The second is in the the car, to the left of your 'dead pedal', or left foot rest.
Locations of the fuse panels can be found here:http://www.infiniti.com/pdf/te...e.pdfpages 267-269
However, I don't think there is a separate fuse for the foglights in the 06-07 models, unless you are talking about something the dealer installed. The lower light in the headlamps are considered fog-lights normally. If you are talking about those, I'm pretty sure they share the same fuse as your headlamps.
hiphopinstitute_com
Car: G35 2007
It's the factory fog lights housing
I open the fuse box on both locations, but there is not indication of a fuse for a fog light, in the manual doesn't say anything but take it to the dealer for maintenance, I believe they do that to keep the service dept profitable.
