fog light installation write up
All things Altima Coupe.
nctarheelz2
Car: 2008 altima coupe 2.5
hey havnt been on this forum in awhile but i was wondering if anybody had a write up for installation on fog lights on an 08 altima coupe 2.5S. Ive been searching everywhere for some instructions and i dont wanna pay like $200 for a shop to install them for me. If anyone can help with this issue or have any advice to give me im all ears!
ty_tanium909
Car: 2008 Altima Coupe 2.5S
i guess the first question would be, are you prewired for fogs already? or do you have to do all of the wiring?
nctarheelz2
I'm pretty sure I'm not pre-wired for my car
SVTboy01
Car: 2010 2.5S AC
how can you tell if you are pre-wired?
Irvxing
Car: 2011 Altima Coupe 2.5s M/T
Remove your bumper and see if youre pre wired. (08-09 models)
The harness should be taped to the wiper fluid reservoir and another harness on the right side (cant remeber the exact location, but its there)
If you are then let me know and i can guide you through the wire tap process to wire your fogs to your existing headlight stalk
(10+ AC Models) Remove the little bumper fog cover and feel around the wiper fluid reservoir for the OE fog harness.
EDIT:
If youre a 10+ AC you SHOULD be pre wired. 08-09 models i believe only the convenience package and tech packages come pre wired.
AlexN09
Car: 2011 Nissan Altima Coupe S 2.5
Are you suggesting that he could utilize the factory fog wiring and tap into the headlight circuit?
Irvxing
AlexN09 wrote:Are you suggesting that he could utilize the factory fog wiring and tap into the headlight circuit?
Correct, i wired a friends fogs that way and did mine this way.
All you need to do is a simple wire tap to the Stalk harness.
Green/yellow to red/yellow cables.
AlexN09
very cool! I know an even easierrrr way to know if you're prewired!! it only takes a minute too.
mrodrig2
Car: 2008 Altima Coupe 2.5S CVT
nctarheelz2,
Open up your hood.
Open up the underhood fuse box on the right hand side.
Look at the small rectanglur power block on the lower right side of the fuse box, I believe it is a 5row x 2column strip.
Look at pin outs 86+87 which are the bottom two on the first column.
If there are two wires coming from these two outputs then you are prewired for fogs.
If you are prewired, just buy the fogs and connect them to the factory harness. If you get an aftermarket H11 kit, just throw away the switch/harness that they include and connect directly to the factory one.
If you aren't prewired, you can use any switch you want; or, buy the OEM combination stalk with fog lights and jam two 16ga wires in the 86 and 87 pinouts to run to your fogs for power then ground them anywhere you like.
AlexN09
AND you have to get the new steering wheel stalk with the foglight switch
mrodrig2
Yes, thanks for the correction.
