yes, you 100% right. i pretty much re-created the problem you are tryng to avoid LOLOLOL. yes pin86 should go to the parking light wire as its trigger/switchandygold wrote:You have terminal 86 going to a high beam lightbulb. Shouldn't it go to a parking light wire for the trigger? That's to energize the relay...but where then does my OEM column mounted fog light switch come into play?
Between these two wiring kits, which would you choose to go with. I do plan on putting in hids eventually if that changes things.5.56 wrote:there will be no power in the stock harness, since your steering wheel combination switch doesnt have the foglight option installed. so using the stock harness is useless, and only serves to complicate your intended instillation.
do it right, and run a whole new harness, with your desired switch.
PS: we already have a foglight thread, for your year. i just merged your threads and renamed it
the fact that you are wanting to install HID's in the future holds no bearing upon the harness you are seeking for a foglight kit.jumpin4abeat wrote:Between these two wiring kits, which would you choose to go with. I do plan on putting in hids eventually if that changes things.5.56 wrote:there will be no power in the stock harness, since your steering wheel combination switch doesnt have the foglight option installed. so using the stock harness is useless, and only serves to complicate your intended instillation.
http://www.amazon.com/gp/product/B00K1N ... FL6KP7KNVP
http://www.amazon.com/gp/product/B00D1C ... GZSAEVCYKA
Welcome, as Rogue one says, use the search, but I would say no they wont work as you need H11. Also COB LEDs are no way a bright as SMD so doubt they would be all that good.. have a trawl through this thread and make up your mind on what u see...swordstool wrote:New owner here. Just purchased a 2016 Rogue SL. I'm looking to upgrade the fog lights to LED. Can I just replace the fog light bulbs with LED conversion kit bulbs? I see these on Amazon that look like the right bulb size for the fogs:
https://amzn.com/B01J6YGGZ8
Will this work, or am I missing something? My experience with light bulbs for cars is limited to replacing headlight bulbs. Also, will these fit with the added length and wire (shown in one of the Amazon photos)?
We have an incredible SEARCH feature on this forum, and this is at least the second time I've suggested that you make use of it. Merged with existing thread.burrpenick wrote:Surely someone has run a wire thru the firewall on their Rogue, hoping someone can tell me the easiest location!
ImStricken06 wrote:THIS IS A WARNING TO ALL NEW AND SEASONED USERS:
If you fail to follow the above rules: you will be issued infraction points. Enough points, and you will be banned. We (mods) simply do not have enough time to handle the constant flow of bad forum etiquette. It's your job to follow the rules. It's your job to do your own research on here. It's your job to add and share here. It's the Mods job to tidy things up - not babysit.
- 1. USE THE SEARCH FUNCTION: ODDS ARE, Every topic you can come up with, has already been discussed. Sorry, but your question doesn't deserve its own thread, if a thread has already been started. If the topic has not been discussed, then feel free to create a new thread...
A lot of already opened threads, can be found here: ROGUE DIY REPAIRS & MAINTENANCE, FAQ & INFO, TIPS, etc
Thank you for your understanding, patience, and commitment to making this place the best ROGUE forum on the net.
-ImStricken
