Hey Faja, thanks for your reply. Glad to know that it isn't necessary to punch new holes. I really appreciate your help w/ the pics of that firewall. How did you access it though? Did you go from the interior and push it out?
I just used the brackets that came w/ the fog light kit. My friend and I drilled a small hole into the extended plastic, and used an extended screw to reach into the bracket. I wish I had taken photos but I left my camera at home when I went to install these w/ my buddy.
Here is a drawing I did of how I got the fogs installed. Hope it sorta makes sense. Here is a close up pic at the best angle I can get from the outside with exposure set very high.
When closeup, you can actually see the screw, best angle I can get with no modification to the bracket....
More picures of how they look can be seen here:
http://www.cardomain.com/ride/3136491
Modified by gforever at 7:39 PM 3/29/2009
Modified by gforever at 7:43 PM 3/29/2009
