Jlor1002 »
https://forums.nicoclub.com/jlor1002-u199104.html
Wed May 08, 2013 2:39 pm
I have been looking to replace my OEM fog light bulbs. I don't like the yellow glow of halogens and am not concerned with the actual function of my fogs, so I ordered some LED bulbs (that supposedly aren't very bright). I just want the color to match my headlights. I tried a couple different halogens first and as I was switching bulbs I noticed one of the housings appears to have some rust in it and the lens is starting to get foggy.
Anyone have any suggestions as to how to clean it? I was thinking of removing it and trying to clean what I can through the hole the bulb sticks through. I'm assuming I shouldn't use anything abrasive or run I'll the risk of damaging the reflective part? Any better strategies out there? Also, how would I go about preventing it from getting dirty again? I'm assuming it isn't fully sealed and needs silicone? ....if so, how do I do that??
And I don't even know if I know how to remove my fog lights. I'm thinking you remove the black plastic cover on the bottom of the car, then remove the black plastic housing piece, then remove the bulb from the housing, then unscrew the housing?
Thanks in advance for any help!!
