fog light bypass
bina12834
Car: 06 G35 coupe
so i found this thread and was wondering if the same technique can apply to our cars?
http://www.clubfrontier.org/fo...-2991/
mpbclutch33
Car: 2008 Altima Coupe 3.5L, 6-speed, Radiant Silver.
I posted this already months ago when this discussion was going around. I had a 05' Frontier with this done and it worked great for 2 years until I traded it in. I tried it on the Altima and could not get it to work. Post if you try and it works for you. The best part is, there is not splicing of wiring and totally reversable.
http://forums.altimas.org/zerothread?id=359494
bina12834
Car: 06 G35 coupe
so with this mod, if we put the "add a circuit" thing into the clearence lamp spot (im assuming the clearence lamps are the parking lights since i dont see a fuse for "parking lights"), and ran the wire down into the fog light fuse hole, this would make the fog lights come on any time the parking lights are on? Im not good with electrics and wiring, so please someone enlighten me because i plan on doing this this weekend if its going to work.
bina12834
Car: 06 G35 coupe
mpbclutch33 wrote:The best part is, there is not splicing of wiring and totally reversable.
thats exactly why i want to do it this way
mpbclutch33
Oh.... The other problem I ran into when I tried to do this over the summer, is that the fuses are the Lo-Profile Mini's, not the standard Mini's and they are supposed to fit in there, but I could not get them to stay properly. On the Frontier, they used the standard mini's. Just an FYI...
bina12834
Car: 06 G35 coupe
hmmm i guess this wasnt as easy of a project as i thought.....of well.
