Fog Light Bulbs
rjchoops
Car: 08 Rogue SL AWD
Has anyone changed out their Fog Light bulbs for a higher watt like the 80 watt cosmic white? http://www.nokyausa.com/cw/cw8018.html
Randy
rjchoops
Still looking for help on changing the Fog light bulbs. How difficult is it to remove the stock bulbs? Randy
audtatious
I would avoid upgrading to 80w bulbs as the higher draw has been known to fry the foglight wiring harness in some other Nissan vehicles. This may not happen with the Rogue but I sure would not want to be the first one to find out
philipa_240sx
rjchoops wrote:Still looking for help on changing the Fog light bulbs. How difficult is it to remove the stock bulbs? Randy
It's in your owners manual, page 8-28. You simply remove an access panel below the bumper, twist the bulb 1/8 of a turn counterclockwise and it comes out. The push pins holding the access panel can be removed using a screwdriver. Simply pry the centre of the pin out then remove the entire pin.
rjchoops
Thanks for the responses, maybe I'll order the Luminics H11 Yellow 55w bulbs at
http://www.luminicsusa.com/det...-H11F
Randy
audtatious
Alternatively you can get HID's if you wanted. I have 6000k HID fogs and headlights.
Return to “Rogue Forum”
