I was going to do a separate writeup, but since you asked....
remove the outer corner fake lens....pry out carefully from the BOTTOM with a thin flatblade... not the top.
looks like this right?
loosen top bolt
loosen bottom bolt
then there is a screw on the inside that sits in that white plastic clip..
get a long Phillips... work it loose... then you should be able to pull the whole lens forward and and out to the side away from the center of the car.
here's a shot of that weird bolt on the inner side of the foglight fixture...
Good luck... try some 55k 4300k HID's and tell me how they work out should look great on the backroads....
