Fog Light assembly?
dfowler
Car: 1994 Infiniti Q45
I recently purchased a Q45, but it was badly maintanced. Luckly, I found another one and swapped but no fog lights. Not a problem cuz I swap the ones from the first car to put on the new one. Problem is that I left the bracket to mount the fog lights to on the other car. Any one know how to remove the mounting harness that the fog lights mount to? Oh yeah, I got parts for 94 Q 45, holla at ya boy. Got a 10 discSony changer too!!!
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
IM 99% sure that the fog light had no bracket, it just screws into the bumper.. Been a while since Ive messed with that stuff.
ILuvNkdChx
Car: Q45t, I30t
Hello, and welcome! You can download the Factory Service Manual or FSM from http://www.phatg20.net. Click on downloads and then FSM's, I encourage you to use the search button more than posting, because as of late, more threads are turning in to arguments rather than anything constructive. If you are truly interested in your Q, start by reading posts written by: Q45tech, Elwesso, maxnix, Rex and Q451990. I have found that if you read you barely have to post at all.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
elwesso wrote:IM 99% sure that the fog light had no bracket, it just screws into the bumper.. Been a while since Ive messed with that stuff.
Must have been, Wes. There are brackets. I may have an extra.
elwesso
2007 BMW M Coupe
is the bracket on the bumper or on the fog light?
dfowler
The bracket mounts to the inside of the bumper. Luckily, I found the ones on the first Q I had. The only problem is mounting them depending on the way the mounting screws are facing. Had a real hard time removing them from the first Q. I had to remove the windshield wiper tank, the head lights, and the wind tunnel on the driver side. Lucky for me, the mounting screws were already positioned from the top coming out the bottom. So no headlight removal for me. One main thing is pissing me off, Im having a bad window problem. I was my rear driver side window. Thought it was the motor and regulator so I bought one. Next, my front passenger window starts the same thing. I know the motor still works but the wire is tangled up. Is there a quick fix or do I have to buy another window motor and regulator. PS, if any one needs parts for a 94 Q holla at cha boy, I could hook u up!!!
