Fog Lamps on a 1998 Pathfinder
Pianodemon
Car: 1998 Nissan Pathfinder LE
The passenger side fog lamp has been off for some time on my '98 Pathfinder. Is it a matter of simply replacing the bulb or do I need to get a whole new fog lamp assembly?
If it's a matter of replacing the bulb, does anyone have experience doing it on this model year Pathy?
Thanks,Alan
QX4ME
Car: 02 Infiniti QX4 4WD
11 MB C300 Sports
06 Honda Odyssey
It is the bulb replacement only, H3 type which is the same across many years. I replaced it on my 02 QX4. Very easy to do. I am not sure how easy phisically on your 1998 Pathfinder.
Do not touch the bulb glass part with your bare fingers at any time and you are fine.
Pianodemon
Thanks, QX4ME, but the fog lights are way different on a Pathfinder and QX4, as far as I know. The QX4 has them mounted under the headlights and are larger , whereas the Pathfinder (at least the 1998) has them mounted below the grille and the are small and bar-shaped.
Empty V
Car: 2001 Infiniti QX4
1982 Chevy Corvette C3 Shark
Pianodemon wrote:Thanks, QX4ME, but the fog lights are way different on a Pathfinder and QX4, as far as I know. The QX4 has them mounted under the headlights and are larger , whereas the Pathfinder (at least the 1998) has them mounted below the grille and the are small and bar-shaped.
The fogs for the QX4 are not under the headlight, they're in the same spot as the pathy. I think this was discussed recently in one of the fog light HID threads or that might have been a gen 1 QX4 vs a gen 2.
Billy
Pianodemon
Thanks, Empty V.
My Pathfinder has foglights like in this picture:
http://upload.wikimedia.org/wa...r.jpg
All of the QX4s I see have the lights mounted as in this pic:
http://www.edmunds.com/picture...9.jpg
Just trying to clarify the type and shape of my foglamps before I attempt any unscrewing/repair of them.
Thanks!
