fog lamps for 2013 g37x
shaneg37x
Car: 2013 infiniti g37x
Do I have to use load resistors to upgrade factory fog lamp bulbs to L.E.D. bulbs ?
telcoman
What is the current draw between the two?
Telcoman
shaneg37x
telcoman wrote:What is the current draw between the two?
Telcoman
I am not really sure. I haven't took the stock bulbs out to check them yet.
shaneg37x
I will check the stats on the new bulbs I am looking at and get back to ya.
shaneg37x
specification:
Color: White 6000k
Power: 12V 15W
Actual Lumen: 560lm
Size:18mm x 57mm
Voltage: DC12V-24V
Input: 420mA±20
Lumens: 560lm±50
Led Type:15pcs Genuine Samsung 2323
Housing Material: Aluminum Alloy
These are the specs. of the ones that I want to Install.
telcoman
Have you read the FSM and the relationship between the ECM, and IDPM?
http://www.nicoclub.com/FSM/G37/Sedan/2013/EXL.pdf
Changes in voltage and current draw may present you unforeseen problems
Telcoman
shaneg37x
I have not......I will check it out though. Thanks.
