Fog lamp connector & headlight ?
pgt892
Car: 1997 240SX
Alright well I have a couple of questions concerning my 97 240. First, I noticed that my front fog lamps don't work. I looked behind them and noticed that the orange/blue female connector for each was without a partner. I looked around for awhile (it's cold outside) and I couldn't seem to locate the male orange/blue connector for the fogs. If someone could give me a heads up as to where to find the connector, i.e. what wires it comes off of etc.. Secondly, my headlamps are not aligned correctly and while the little levels on the headlamps tell me this, I can't figure out how to align it correctly. Any help would be appreciated, thanks.
pgt892
Car: 1997 240SX
^Bump^
Dano
Car: '05 Nissan Frontier Nismo CC
'95 Nissan 240SX base
as for the headlights, consult the factory owner's manual in the car and adjust them on a wall.... and as for the fog lights, the wires for the fogs should run off of the headlight/lighting wires/harness.... just go to nissan to get two new connectors, thatd be the easiest way to do it....
-Dan
pgt892
Car: 1997 240SX
240sx2nr95 wrote:as for the headlights, consult the factory owner's manual in the car and adjust them on a wall.... and as for the fog lights, the wires for the fogs should run off of the headlight/lighting wires/harness.... just go to nissan to get two new connectors, thatd be the easiest way to do it....
-Dan
The problem with the headlamps is that I don't have the owner's manual.
Dano
can some1 give him the info? i dont have it right here, but when im not busy if no1's posted the info by tomorrow, ill get u the info from the owner's manual, alrite?
-Dan:)
