FOB won't program
qx4inoxnard
Car: 2001 Infinit QX4
Hi All,
Neither my original FOB (kbrastu10) nor replacement (krbastu15) bought on Amazon will reprogram using the recommended steps:
1 Close all doors and lock all doors
2 Insert and remove the key from the ignition key cylinder more than six times within 10 seconds. The hazard warning lamp will then flash.)
NOTE:Key should be withdrawn from ignition key cylinder completely each time.
NOTE:Do not rush the insertion/removal key cycling process. The side marker/tail/license lamps and interior illumination will flash twice when this step is accurately completed.
3 Insert key on ignition key cylinder and turn ignition key switch to "AAC" position At this time, the new ID code is entered and original (previous) ID codes are erase.
4 Press any button on the new remote controller once. (The hazard warning lamp will then flash)
NOTE:Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming procedure will not be successful. The side marker/tail/license lamps and interior illumination will flash twice when this step is accurately completed and programming is successful.
NOTE:If there is only one remote controller skip step 5.
5 Additional ID code entry Release the door lock, then lock again with door lock/unlock switch (In power window main switch)
6 Remove key from ignition
7 Unlock driver side door, open driver side door and then close the door. (END)
NOTE:If you need to activate more than two additional new remote controllers, repeat the procedure on step 5 Additional ID code entry for each new remote controller.
NOTE:Entry of maximum four ID codes is allowed and any attempt to enter more will be ignore.
I also used this video https www youtube com/watch?v=es_f3IMmD20 as a reference for the process and the model I purchased, but still no go - ugh!
The truck goes into program mode following step 3 but none of the FOBS will make it flash in step 4.
Anyone have the same problem and get it figured out? Help!
qx4inoxnard
OK I have an update for anyone interested. The original FOB that came with the truck kbrastu10 mdl a definitely sends a signal, I had it tested. I also know that it takes model a and not model 1a because the vehicle sticker indicates June of 2000 which calls for the model a according to numerous sources.
It seems like now the culprit might be something to do with the vehicle as opposed to the remotes. Any thoughts?
