2004? FOB and not Intelligent key? Could you explain a bit further?
"I changed the batteries and tried to unlock/lock the car and it does not work."
I presume you mean it stopped working, you put new batteries in the FOB, and it still is not working?
"I have 3 other devices that I programmed at the same time and none of them work."
Does this mean you have 4 different key fobs you are using with the same car?
"I have ruled out that it Is the Fob themselves."
How did you do that? Do any of them open the trunk or set the alarm off?
Beginning on page 50 of this manual:
http://www.nicoclub.com/FSM/G35/Sedan/2004/bl.pdf
you will find the info about your "remote keyless entry system" The first thing to note is all of the fuses involved. Start by checking each of them.
