lanman_4 wrote:bicsintegra, were you able to get the key to the point of reprogramming? (dash lights flash etc..)?
I have changed the battery in my second fob, didn't help. When I attempt to start the car with the key in my pocket (not in the key holder in the dash), I get a message of Key ID: NO
L
That special thickness is 2.5mm. The 20 is the diameter, which is 2cm (20mm). These are industry standard sizes, and any battery that says it replaces CR2025 (or anything 2025 or 2025 anything) is the same thickness and diameter. A battery designated as a 2032 would look the same but actually be .7mm thicker (and a 2011 would actually be 1.4mm thinner). The number is basically like an A or AA to the batteries you are more familiar with, and there is nothing special about the Sony, other than possibly the price. I figured out the size thing on my own after changing about 3 different button cell batteries in a row. I more recently learned the following from wikipedia:jmccarthy100 wrote:The Infiniti dealer quoted me $10 for a fob battery -because - and I quote ' the CR2025 battery for it is specially made to a certain thickness' - (even though its a Sony OEM battery?) . I didn't ask what they charge to reprogram it but everything about the service for this vehicle seems to be a bit of a cash grab. I found it hard to believe that is a 'special' battery although I may go get a Sony and see if it makes any difference.
2. Insert and remove the key from the ignition key cylinder more than six times within 10 seconds.infiniti_lineup wrote:Yeppers! Please follow these instructions:
To reprogram (enter new ID) key fob (keyless remote controller) follow the steps.
1. Close all doors and lock all doors
(The hazard warning lamp will then flash.)
NOTE:
Key should be withdrawn from ignition key cylinder completely each time.
NOTE:
Do not rush the insertion/removal key cycling process. The side marker/tail/license lamps and interior illumination will flash twice when this step is accurately completed.
3. Insert key on ignition key cylinder and turn ignition key switch to "AAC" position
At this time, the new ID code is entered and original (previous) ID codes are erase.
4. Press any button on the new remote controller once. (The hazard warning lamp will then flash)
NOTE:
Do not press the button more than one time in the above step. If the button is pressed more than one time, the programming procedure will not be successful. The side marker/tail/license lamps and interior illumination will flash twice when this step is accurately completed and programming is successful.
If there is only one remote controller skip step 5.
5. Additional ID code entry
Release the door lock, then lock again with door lock/unlock switch (In power window main switch)
6. Remove key from ignition
7. Unlock driver side door, open driver side door and then close the door. (END)
NOTE:
If you need to activate more than two additional new remote controllers, repeat the procedure on step 5 "Additional ID code entry" for each new remote controller.
NOTE:
Entry of maximum four ID codes is allowed and any attempt to enter more will be ignore.
